szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
kendybar
Jun 15, 2014Aspirant
Hi people.
I upgrated from a wndr3400v2 to the r7000 3 days ago. At first, I was really happy because transfers from "readyshare" to my pc went from 4 MB/s to 60 MB/s. Range was also better.
However, yesterday I tried downloading a 17 GB torrent to the readyshare USB drive. About halfway through, all the files that were downloaded disappeared. The folder was still there but it was empty and I couldn't delete it. I had to unplug the drive, and plug it in my pc to delete it. Then I restarted the download and it worked. But this morning the files were gone again. Same problem, I couldn't delete the folder with the following error message: "You require permission from Unis User\nobody to make changes to this folder". This is very annoying and I'm afraid to loose more data. I hope the damage is limited to this torrent only. Anyways, I just wanted to let you guys know since this thread hadn't had any activity in a couple months. I want to let you know that this issue is still there with the latest firmware (V1.0.3.60_1.1.27). I'll be returning this router and go back to my good old wndr3400v2.
P.S. I also loose all connections (wired and wifi) about once per day since I got the R7000. It could be related to the USB problems, I don't know.
Cheers!
Cheers!
