szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
WAS_1
Jun 16, 2014Aspirant
Yes, I'm also still getting NTFS file system corruptions on a USB3 connected flashdrive as discussed in my Feb 2014 thread:
This also occurs with the latest firmware and even after a lengthy and frustrating dialog with support earlier in the year.
Ok, connected the flashdrive to the PC and ran chkdsk. Errors were found and corrected. Re-connected the flashdrive to the R7000 USB3 socket and copied the smaller 2 GB file. File copied ok. Copied the larger 93 GB file and it was corrupted as before. Re-connected the flashdrive to the PC and ran chkdsk again. Following corrections made AGAIN:
Correcting errors in the master file table's (MFT) BITMAP attribute.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
Looks like the first copy corrupts the file system!
