szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
Retired_Member
Jun 22, 2014CDLNet,
This also worked for me, temporarily, but the problem came back. I am trying to use the share for Windows 8 File History, and I'm concerned that the 'Clean up Versions" feature won't work. One thing that I plan on trying is to use the "connect using different credentials" with the Netgear admin user and password when I use the 'Map Network Drive" function in Windows 8.
