szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
Inolvidable
Jun 23, 2014Aspirant
kendybar, WAS_1
I is an annoying issue that also made me lose data non to mention I could not use Ready share vault either.
htismaqe,
You are right. I changed NTFS for EXT4 five months ago and has worked flawlessly ever since in a heavy use environment.
Dave_O,
I will try. Thanks for the tip
htismaqe,
Dave_O,
