szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
barry_davis
Sep 05, 2014Aspirant
Just upgraded my router from Asus AC56 to R7000 and started having similar problems.
In my case I discovered that if I try to execute a program (ie, install from the router share) sometimes after the program is executed it will show as a 0 byte file. I then get a message that the file is no longer in that location and can not be deleted.
Firmware is V1.0.3.60_1.1.27 although having just checked it I see there is a newer version now but none of the fixes seem to address the file system.
