szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
barry_davis
Sep 18, 2014Aspirant
As a follow-up (even though this thread seems dead), I have installed latest firmware V1.0.3.68_1.1.31 and still have problems with USB3 attached drive.
I have recently noticed when copying FILES from a W7 system to the drive attached to R7000 the R7000 will change the FILE to a FOLDER. Sometimes the file will copy OK but when I look at it later it will be 0 byte. Sometimes it will be OK on the R7000 UNTIL I go to copy it and then I get a message it isn't available and when I look it has turned into a FOLDER or 0 byte FILE.
I'm thinking I either have to go back to my Asus AC56 or attach the drive to a W7 system for sharing.
This R7000 just isn't worth the hassle of losing files all the time.
