szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
SimonHK
Sep 26, 2014Aspirant
I too am having permissioning errors. Trying to delete some files (not all), I get an error saying "You require permission from Unix User\nobody to make changes to this file".
Using Firmware version V1.0.3.68_1.1.31
Sometimes the unchecking readonly attribute works, sometimes it doesn't take.
The USB drive is formatted in NTFS, when I unmount it and connect to a Windows machine I'm able to successfully delete it.
