szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
Kurt_NEPA
Oct 23, 2014Aspirant
Same problem here. I have a Western Digital 2TB USB3 drive hooked up to my R7000. All went well for a short while. Now the security settings are being changed all over my drive. That results in revoking my privileges. My USB drive is my back-up drive and this problem is really interfering with my back up program.
I've been following this thread for sometime hoping for a solution, but nothing is working for me. So far we have not gotten a comment one way or the other from Netgear. Is anybody listening?
:mad::(:confused:
:mad::(:confused:
