szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
JameyG03
Dec 19, 2014Aspirant
Has anyone had this issue with the newest firmware update (V1.0.3.80_1.1.38)? I just updated but am worried about plugging my hard drive in because I lost 27 of of my 73 files last time (all movies). Netgear you need to get your heads out of your you know where. I've lost 37% of the files on the hard drive connected to your router. You should be offering people a newer/upgraded version of the router since obvious nothing you are doing is fixing the problem.
