szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
nizz
Feb 27, 2015Novice
I formatted mine to ext4 and use Win8 to manage it over network. Just right click the main folder with issue and uncheck READ ONLY and apply to all folders. This does solve it.
The folders will at some point make themselves READ ONLY again, not sure why, but if you are unable to delete something just make sure its not READ ONLY.
The drive was NTFS but I decided to format to ext4 since it lives on the usb3 port and since going to ext4 setting the read only flag is about 1,000x faster than it was on NTFS.
