szewski
Jan 08, 2014Guide
R7000 NAS Drive Can't Delete Files Folders Permissions Issue User \ Nobody
I have the R7000 with a Seagate STBV4000100 4TB USB 3.0 drive connected. I can connect to it just fine, drive shares work etc. From a WIN 7 64bit OS system using windows explorer I can create folders...
- May 08, 2016
After a few reformats of the drive, it worked for me. The files on the eSata drive are exactly like the "standard" Windows Explorer. I can save, load, delete, change properties etc... Since it worked, I had to power down the router once, and after a restart, nothing had changed. Everything still working. (except the bad 5G wifi, and the "freaky" interface, but that was like before)...
ecquack
Apr 13, 2015Aspirant
Workaround:
Connect to the drive via FTP. This allows you to rename and delete files that you can't administer from Windows. It's not a perfect solution but it saves having to unplug the USB drive and move it to the PC temporarily.
I use the freeware FileZilla FTP client and just connect to NETGEAR7.routerlogin.net/shares (I changed my router to the name NETGEAR7- your actual name will be different. I think the default is "FRONTPORT".
-E
-E
