annistyt's avatar
annistyt
R7000 Nighawk Internet speed limited
So I connected my ethernet cable to my pc and I checked on speedtest to verify and test the internet speed. We have fiber and our download/upload speed is 500/50 mbps. When I tested on speedtest I only got 300/50 mbps.
I even tried testing on other computers and cables. I know 300 mbps is enough, but we pay for 500 mbps and I wonder why I won't get that speed when using a cable.
The router is updated to the newest version: V1.0.9.18_1.2.27
For some months ago when we first got fiber and purchased the router I got 500/50 with a cable connected to the router on my laptop. But now it's limited at 300/50.
I know it's a **bleep**ty written article but I'm not really good at it.
Thanks!
  • Things that people have tried to fix the "router is throttling my modem" issue with various devices:
    • Ensure that the cable from the router to the modem is up to the job
    • Check that you have the latest firmware (and "factory reset" the device)
    • Check that you have the right internet settings for your ISP (especially MTU)
    • Turn off QoS
    • Turn off the Traffic Meter
    Netgear also advises that you should turn off QoS if you are on Gigabit Internet. You don't need it.
  • michaelkenward's avatar
    michaelkenward
    • Turn off QoS
    • annistyt's avatar
      annistyt
      I did a factory reset and I got 500/50 on speedtest, thank you
        michaelkenward
        And yet there are still people who see no point in a factory reset. It doesn't always help, but it seems silly to not even try it.
        Thanks for the feedback.
