geoffleach's avatar
geoffleach
R7000 Nighthawk
Laptop looses 1/3 of wifi signal strength when the laptop moves through a door. Distance to router at that point is 10 feet. Wall is conventional wood-framed. On both sides of the wal there are fully loaded bookshelved, with vertical steel supports.
Thopughts? Solutions?
Thanks.
  • Sounds about right to me. From what you describe the wifi is going through a wall plus two layers of books plus steel shelving.  Remember wifi does not go around corners.
    • geoffleach's avatar
      geoffleach
      Hmmmm ... interesting.  Other than moving the router, is there a solution?
    • antinode's avatar
      antinode
      Guru
      > [...] Remember wifi does not go around corners.
         This would make them the first EM waves ever not to experience
      diffraction.
      • myersw's avatar
        myersw
        Master
        diffraction.
        True, but remember that signals that spread or bounce are not going to provide as good of a signal as nothing inbetween.
