algje
Nov 02, 2016Aspirant
r7000 no usb 3.0 with latest firmware
I know this has been much discussed, but I couldn't find the solution in any of the topics after searching for days. Has there been a solution to the usb 3.0 port not working, whereas the usb 2.0 is working fine with an external hard drive? The only solution that's being mentioned is a firmware upgrade, but I'm running a later firmware version to the one that is suggested. I'm on V1.0.7.2_1.1.93. Moreover, the topics I find are over a year old, surely a solution has been found in the meantime?
Thanks.
Hi nexusone,
Please check the KB article for the external drives that works with the router.
http://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
- JamesGLNETGEAR Employee Retired
Hi algje,
1. Did the issue happen before updating the firmware?
2. What is the model number of the drive?
3. Do you have other 3.0 drive to check the USB 3.0 port of the router?
JamesGL
Community Team- algjeAspirant
Hi James,
Thanks for replying. The answer to question 1 I don't know, since teh firmware was upgraded before I did anything, so I've only had this version. The drive is a seagate srd00f2. It worked fine until I unplugged the router. After that I've tried resetting the router (as per your advice in another topic) and that seemed to work until the router was unplugged again. I've just tried resetting the router again, but this time it doesn't seem to have helped. I think there was some language update somewhere in between that.
I haven't checked another drive, as this drive was recognized before, so the drive itself seems fine.
Thanks.
Hi algje,
1. If you connect the drive in USB 2.0, will it work?
2. If not, will your computer detects the drive if you connect it directly?
3. Please try using a different drive just to isolate.
JamesGL
Community Team
Hi algje,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team - algjeAspirantYes, it works fine in the 2.0 port and directly in my pc or laptop. I will try another drive to be sure and report back asap.
- nexusoneTutor
Seens like this has been a topic of discussion for like a year now so i tend to think the "firmware" issue is a cover up for a disfunctional 3.0 port.
Can the admins confirm that external 3.0 hard drives actually work when plugged into the USB 3.0 port in the front of the router or is the only option the 2.0 port?
This is misleading because the router advertises the ability to connect a drive at 3.0 speeds.
Are there any known limitiations? Has anyone ever been able to recognize a drive in the 3.0 port?
Thanks
Hi nexusone,
Hi nexusone,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
