grayjaso1
Jan 28, 2016Aspirant
R7000 problems since latest firmware update - which firmware is stable/should I revert to?
I need to perform a firmware upgrade on one of my r7000 routers that is notably behind in this respect. The one that has been upgraded to the latest firmware has had more network drops and performanc...
- Apr 27, 2016
I previously experienced the same performance issue as you and since I have been using the FW BETA 1.0.5.60 (for at least a couple of weeks now), I haven't seen the performance degradation. Also, a new FW BETA version 1.0.5.62 just came out and you might want to try that. v60 has worked for me so far...
Also, although there seem to be different Community opinions on whether this is really necessary, I did a factory reset on the router before AND after the firmware updates. Then I customized my settings (e.g. passwords, SmartConnect option, MTU packet size setting, etc.) manually to my desired settings. You might want to try that to ensure a 'clean' configuration.
bytat
Feb 08, 2016Tutor
Don't forget to press the reset button, located in the tiny hole at the back of the router, for 30 seconds after you've installed the firmware and manually re-configure all your settings. Don't load a backup file since that'll effectivally cancel out the reset.
- JamesGLFeb 09, 2016NETGEAR Employee Retired
Hi No_ROI,
Please reset the router to factory default and manually reconfigure the router.
