grayjaso1
Jan 28, 2016Aspirant
R7000 problems since latest firmware update - which firmware is stable/should I revert to?
I need to perform a firmware upgrade on one of my r7000 routers that is notably behind in this respect. The one that has been upgraded to the latest firmware has had more network drops and performanc...
- Apr 27, 2016
I previously experienced the same performance issue as you and since I have been using the FW BETA 1.0.5.60 (for at least a couple of weeks now), I haven't seen the performance degradation. Also, a new FW BETA version 1.0.5.62 just came out and you might want to try that. v60 has worked for me so far...
Also, although there seem to be different Community opinions on whether this is really necessary, I did a factory reset on the router before AND after the firmware updates. Then I customized my settings (e.g. passwords, SmartConnect option, MTU packet size setting, etc.) manually to my desired settings. You might want to try that to ensure a 'clean' configuration.
Kaptajnen
Apr 26, 2016Aspirant
James,
i have been waiting patiently for news of a stable firmware for my Nighthawk R7000.
I am running version 1.0.6.28 and I have to reboot every 24 hours... This is not acceptable for a premium product.
Please advise.
thank you
grayjaso1
Apr 27, 2016Aspirant
- JamesGLMay 01, 2016NETGEAR Employee Retired
Hi Kaptajnen,
Here is the link for the beta firmware.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/td-p/1078114
- JamesGLMay 04, 2016NETGEAR Employee Retired
Hi Kaptajnen,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
