lookiesh's avatar
lookiesh
Follower
Mar 26, 2022
R7000 router is very unstable and need a help!
Hello,
I have R7000 and used it at the office then I relocated to different state and now trying to use it at home.
I had another router (EERO) at home, but the wifi speed was not satisfied so I decided to use the R7000.
Then the router is unstable. The ethernet works fine, but wireless is unstable.
These are the things I already tried:
1. pressed the reset button the router
2. update the firmware
3. power on & off
4.192.168.1-> tried the third # to 2
Still unstable. Please help!!
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Is Armor or Circle enabled on the router?
    • wcalifas's avatar
      wcalifas
      Prodigy
      when you say unstable are you saying that the wifi disconnects or how is it unstable?
