HomeITTech's avatar
HomeITTech
Follower
May 15, 2025
r7000 router only shows two lefthand lights
We lost internet this morning. Verizon Fios says that the internet is all good on their end, so it potentially is a problem with our R7000 router. (https://www.netgear.com/support/product/r7000/)
Only the two left lights are showing and I dont think that's right. Anyone know what I can to do fix it? Do we need a new router??
  • plemans's avatar
    What color are those 2 led's?
    Do you have anything connected to the router wired?
    If the wifi led's aren't on, try pushing the wifi on/off button for 2 seconds
  • Check the power adapter and make sure it’s the original one or provides the correct voltage and amperage. I’ve seen routers act weird or not fully boot with off-brand or failing adapters.
