cool_guy
Jun 29, 2024Aspirant
R7000 Router
I have R7000 router. My ISP upgraded my speed to 500Mpbs and I get about 450Mbps when I connect my PC directly to the modem. But, when I connect my PC to the router, I only get about 200-210Mpbs. Are their any settings that needs to be changed to better speed?
Thank you,
Connect how. 200-210 Mpbs is about right for some wifi technologies.
What is that modem? Make and model?
- cool_guyAspirant
Its a spectrum modem. Not sure what is make and model.
Over the years Spectrum will have handed out dozens of different modems. The details are important. For example, many ISPs like to supply modem/routers that also do wifi and local networking. These do not play nicely with extra routers.
So not knowing that missing detail makes it hard to troubleshoot problems. That's why we ask.
Most devices have a label on them with these missing details.
what modem do you have?
what firmware is on the R7000.
the R7000 is over a decade old. It took some special settings to hit gigabit speeds over wired with it when it came out. Make sure access control, traffic monitoring, parental controls, and qos are all disabled. If there were disabled, try a factory reset and reinstall. Make sure those aren't enabled during the install. then test the wired speed
It predates the time when ISPs offered gigabit Internet.
Back then Netgear still sold routers with LAN ports stuck at 100 Mbps.
