subraarya
Jul 11, 2015Follower
R7000 slow download speeds
only realized after 8 months that my R7000 router always has a download speed close to 3-5 mbps when my ISP provided me 75mbps upload/download. I got latest firm ware updated and customer service ...
- Jul 16, 2015If you have not already, I would reset the router to defaults and without doing any configuration other the connect to the Internet, no wifi etc. Now see what speed you have with a computer connected to Ethernet port. If it is good then add your configuration back in one thing at a time and test again. This should get you to what configuration option that is causing the slowdown.
--bill
rwclemmons
Oct 14, 2015Initiate
I have read many sites with this same issue for the R7000. My ISP provides Fiber to my home with speeds up to 1Gb using PPPoE. I am unable to come close to 50% of throughput for my availible bandwidth. Currently with the R7000 inline and wired to 1 laptop I can obtain 350 Mbps of throughput. Removing the R7000 results in 750 Mbps of throughput.
I reset and configured my router as you recomended and the throughput of the R7000 did "NOT" improve. I could only attain 350 Mbps using the R7000.
I did note some of the first reviews of this router when it performed much better than I am seeing. On the following site it shows the throughput is exceptional but if you note the firmware is an old firmware version V1.0.1.22_1.0.15.
I have started looking at new routers and sadly Netgear is no longer on my list of vendors. I am not purchasing your devices because of the number of customers seeing this problem and the legnth of time you have ignored their voices with an unwillingness to resolve this issues.
williebabeham
Oct 27, 2015Guide
Very poor support from Netgear. I have had this issue intermittently, slow on both frequencies, and on the wired ports, just suddenly, out of the blue. Port 4 actually becomes unresponsive, and does not return a ping.
The latest from Netgear, after having proved that the issue is not with the Cable modem (100Mb/s down), and is definitely with the router, either hardware or software, is that I try changing the DNS to 4.2.2.2!!!
Clearly they are not listening, and really dont care. This is a useless router as its stands Off to buy an Asus, - I cant wait indefinitely until Netgear get serious about fixing this one.
I have no idea how it gets recommended on any site. Its that bad.
- JamesGLNov 03, 2015NETGEAR Employee Retired
- williebabehamNov 05, 2015Guide
Yes, I will thanks you.
In the interim, I beieve I may have found the solution to my isse, that may be helpful to others.
I have been swapping routers bertween the R7000 and an ASUS RT AC66U. I joticed that after a while they both exhibited this problem (though the wired ports on the ASUS were not affected) and monitored closely for a few more days. I saw a time relationship to the problem, - it would happen ar certain times, mainly, but nt always the evening, so being on a Cable network, I monitored the cable feed; there was no drop in speed at thre cable provider side, the speed drop was associated with the router.
Evetually, after monitoring connected clients, one in particular, which had a private MAC address seemd to be connected at the times I had problems.
Turns out it was a Kindle, and my wife was trrning it on, and reading, and the wirelss was on. I turned the wireless off on the Kindle, and the problem disapperared. I went from arounf 2Mb/s down and about 1 up to 69Mb/s down and 4.2 up.
I googled KIndle devices and found that this is very common, mainly with the Kindle Fire; our Kindles, - we have 2 are Kindle Touch models; the other Kindle when powerd on with wireless on, did not show the same issue. I have reloaded the suspect device, and have left its wireless off.
If you have these symptoms, check is you have a Kindle, especially a Fire, and disable its wireless connection. Amazon may have fixes, - they have none for my version.
I will continue to monitor, - the R7000 is now in service, and I will report back. Im not sure exactly what the Kindle was doing, but this precise effect is very common, and can be easily found with a Google search.
I addition to the note I added re the Kindle, I wanted to say that the ASUS CPU was 100%, and the memory usage was 95% during the time the the slow performance/connected device issue was in progress. This was very helpful in troubleshooting.
Is there a way to monitor these parameters in the R7000?
- JamesGLNov 05, 2015NETGEAR Employee Retired
Hi williebabeham,
This feature is not available with the router. This is a great idea and you can offer this suggestion in our Idea Exchange board.
JamesGL
Community Team
