fabraga
Jan 19, 2016Tutor
R7000 V1.0.6.28_1.1.8 "OpenVPN connection timeout"
Bought this router with support for VPN a week ago (Jan 12, 2016) after lots of researches, believing that would be one of the best choices for someone who wants to setup VPN at home. VPN was the mai...
- Jan 20, 2016
I had the same problem, and of course I also could not figure out the problem. until now.....
The problem was a factory reset. My R7000 is connected to the router of my ISP, on that ISP-router I configured a port-redirect to a specific IP adress (that of my R7000). Due to this factory reset, my R7000's IP adress changed, so the solution was quite simple, change the redirect to the new IP adress and it worked again.
I hope this information helps.
2nafish2
Jan 20, 2016Guide
- fabragaJan 20, 2016Tutor
Thanks "2nafish2"!
That makes a lot of sense. If you don't mind me to ask (because although I have learned a lot about networking in the past few days - I'm more like a software developer), in the ISP-router you are talking about FORWARDING, right (not PORT FILTERS and not PORT TRIGGERS)? Because I am looking into my ISP-router ADVANCED tab trying to figure out where exactly to set that redirection.
If it is the "Forwarding" option, I have a few things to set: "Public Port Range" (?-?), "Target IP Address" (I already know), "Target Port Range" (another ?-?), and "Protocol" (I selected "Both" for UDP and TCP). So, my confusion is only with the first and third ones (Public and Target Port ranges). What would be the range? I guess I need to do it for all ports but which are the minimum and maximum values? Would that be safe?
Many thanks anyways! You already pointed where the problem is located.
Fabricio Braga
- fabragaJan 21, 2016Tutor
Never mind! I finally figured it out. Working now! :)
- 2nafish2Jan 21, 2016Guide
I'm glad that I could be helpful, it took me a while too before I had this idea.
I took the settings for redirecting a range of ports to a specific IP, is that forwarding or triggering? I've set a range of 7 ports to my R7000 and 1 to my NAS
It must be safe, and an other option is the DMZ, but only if there aren't any other diveces connected to the ISP-router, DMZ will open all ports without firewall, so the next device (R7000 in my case) must protect itself, and the R7000 can so....
But the problem is solved so, have fun!
