fabraga's avatar
fabraga
Tutor
Jan 19, 2016
R7000 V1.0.6.28_1.1.8 "OpenVPN connection timeout"
Bought this router with support for VPN a week ago (Jan 12, 2016) after lots of researches, believing that would be one of the best choices for someone who wants to setup VPN at home. VPN was the mai...
  • 2nafish2's avatar
    Jan 20, 2016
    I had the same problem, and of course I also could not figure out the problem. until now.....
    The problem was a factory reset. My R7000 is connected to the router of my ISP, on that ISP-router I configured a port-redirect to a specific IP adress (that of my R7000). Due to this factory reset, my R7000's IP adress changed, so the solution was quite simple, change the redirect to the new IP adress and it worked again.
    I hope this information helps.
