fabraga
Jan 19, 2016Tutor
R7000 V1.0.6.28_1.1.8 "OpenVPN connection timeout"
Bought this router with support for VPN a week ago (Jan 12, 2016) after lots of researches, believing that would be one of the best choices for someone who wants to setup VPN at home. VPN was the mai...
- Jan 20, 2016
I had the same problem, and of course I also could not figure out the problem. until now.....
The problem was a factory reset. My R7000 is connected to the router of my ISP, on that ISP-router I configured a port-redirect to a specific IP adress (that of my R7000). Due to this factory reset, my R7000's IP adress changed, so the solution was quite simple, change the redirect to the new IP adress and it worked again.
I hope this information helps.
fabraga
Jan 26, 2016Tutor
I understand NAT is for a hard drive I want to attach to the router, for example, so to share its files to my private network's devices (something I am trying to do right now), but I also understand that if I set DMZ then I don't need to set NAS as everything goes to my new router anyway. Is that right? I am currently having trouble to see the folders in my sharing hard drive while accesing it through a browser although I am not getting any error messages. I can access it, the router's icon shows up, but not the hard drive (and its folders) yet... and I have already added some of these folders to the sharing network in the router. Trying to figure out what am I missing... :/
fabraga
Jan 27, 2016Tutor
All good now. Everything was fine. Just took a while to start functioning.
