CDean's avatar
CDean
Tutor
Mar 03, 2021
R7000 Webex Issue
I can no longer connect to  Webex sessions via my router. It doesnt matter if I use wifi or wired same issue.
Also if my phone is using wifi it will not connect either. I get a timeout error for taking to long to connect. If I turn off my phone wifi it will connect to Webex using cellular. Webex has a test site and my router is not letting me get to it either.
Any Ideas !
  • michaelkenward's avatar
    michaelkenward
    What happenes when you try?
    What tells you that it is the router that is getting in the way?
    Any error messages? Prompts? In what?
    • CDean's avatar
      CDean
      Tutor
      Thats for the reply.
      I got it fixed !
      First I connected to the Cable Modem directly and all was fine.
      That put me back to it being a router issue.
      I started turning off optional items in router.
      When I turned off Qos ... My wired and wireless devices were able to connect to the webex test site without timing out or giving me unable to connect to server messages. .
      Not sure why ???
      • CDean's avatar
        CDean
        Tutor
        I just want to post an update on this issue.
        It turns out that my issues returned. Not just with a particular website but other websites as well.
        I read the Netgear message Boards and found that if you Clone the Mac address it will fix this issue.
        Its hard to believe but it fixed the issue instantly. I need to mention you should reboot your Cable Moden and Router after the change.
        I am not sure why this issue just popped up on a 2 + year old router.  Probably has something to do with Comcast !
