hbk_seanmichael's avatar
May 07, 2017
R7000 What firmware? Stock? DD-WRT? Tomato?
Is stock fine for me?  Or shoud I use a different firmware?  My internet plan is 125mbps download 20mbps upload
I do a lot of streaming at home on my home networking.  Wife streams netflix while I am usually online gaming or streaming live sports.  We have 2 4k tvs so the bandwidth sometimes needed for the 4k video  is higher than normal.
The total devices on our network are:
Ps4 pro,
Xbox one s,
2 65" KU6300 Samsung 4k smart tv
2 samsung s7 edges
samsung 7 series notebook
windows surface
chromecast
roku premiere+
Samsung smart tv 1080p
Obviously all of them are not in use at the same time.  The xbox one S and ps4 pro are wired.  Everything else is wireless.
  • Stock should give you the best performance.  Go to third party firmware for features.  These days, DD-WRT would be my last choice.  Go with Tomato or Asuswrt-Merlin.  Both support hardware acceleration.
    • FURRYe38's avatar
      Theres OpenRouter FW as well. All tailored or NetGear routers and mostly based on NG FW and UI.
      • AhnFire's avatar
        AhnFire
        Guide
        Don't fix what ain't broke! But if it's broke (like mine), I went with Tomato 138 AIO from openrouter. Works better for me, not perfect, but I think I have something else going on in my setup. Just make sure you follow the directions and after each flash, do a factory reset. Good luck!
