nxi
May 22, 2017Aspirant
R7000 wifi dropping connection constantly
Firmware: V1.0.8.34_1.2.15
OS: Windows 10 x64
OS 2: Android N
WiFi 2.4ghz settings
Region North America
Channel Auto (9)
Mode Up to 600 Mbps
Wireless AP On
Broadcast Name On
Wi-Fi Protected Setup Configured
WiFi 5ghz settings
Smart Connect ENABLED
Channel 149 + 153(P) + 157 + 161
Mode Up to 1300 Mbps
Constantly dropping connection over wifi with laptop and android smartphone. The router is unusable at times. It's been like this since the last 2 or 3 firmware updates.
Hi All,
Reset the router to factory default and manually reconfigure it.
- Neu318Aspirant
My Nest thermostat has been dropping every few minutes after the firmware upgrade. My iPhone also disappears from the list of attached devices.
- JamesGLNETGEAR Employee Retired
Hi All,
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Last week I took my R7000 out of service because I (and especially my gamer kids) were getting sick of randomly losing the internet connection. Would happen 3-4 times every day and last from 20 sec. to 1 minute, then "fix itself". I would always update the firmware when a new one was releaded. The new router that I leased from my ISP has worked flawlessly. My ISP has noted ZERO connection problems with the line running to our house.
So I get the restoring factory default process but can you further explain the manual setup procedure? What specific "things" (DNS, IP address, etc.) will I have to do manually? I'd like to be as prepared as possible should I deceide to go this way.
It sucks having a $250 router (purchased 2 years ago) and it doesn't work reliably!
p.s. it worked fine up until a few months ago. I blamed it on the modem but that wasn't the problem.
- When did this firmware come out?
Hi ifishskis,
The firmware was release last week.
