blobdobguy's avatar
blobdobguy
R7000 wifi trouble
I have a weird wifi issue with my Nighthawk. I have some devices (printer, etc) which I can only get to connect to my guest wifi. I enabled both 2.5GHz and 5GHz in different configurations, but I seem to be unable to replicate the one of the guest wifi. I have of course triplechecked the password. Any idea of what could be wrong?
  • What are the Wi-Fi settings (SSID broadcast, security mode, speed mode, channel) on the router?
    Can these devices see the Wi-Fi network?  Are you prompted to enter the password when they try to join the network?
    Do you have MAC address access control enabled on the router?
    • blobdobguy's avatar
      blobdobguy
      SSID broadcast is enabled, security mode is WPA2-PSK, speed mode I tried them all, channel set to auto.
      The devices see the network, I get prompted for the password, but they are unable to connect. The connect fine to the gues one though.
      I don't have MAC address access control.
      • TheEther's avatar
        TheEther
        Guru
        Try switching the channel from auto to a fixed number.
        Try using WPA-PSK or WPA-PSK+WPA2-PSK security.
        If the password has special characters, then try a simpler password (i.e. alphanumeric).
