Den89's avatar
Den89
R7000
I canlog in to my ADMIN account on laptop but can't login to my Nighthawk app using the same ADMIN credentials. it gives me error on the mobile app.
  • you need to have a registered account on NETGEAR to login into the app, AFAIK
    • Den89's avatar
      Den89
      Thanks,
      I do have an netgear account which I ise to log in the app but after that when my router is linked to the app it is requiring another log in using my Admin username. I have am issue during this Admin log in.
      • plemans's avatar
        the login info is case sensitive.
        Make sure you're using lower case admin and not the capital A that you're currently putting in your posts.
    • Den89's avatar
      Den89
      Thanks,
