spadude60
May 12, 2023Aspirant
R7000
I have recently obtained an issue with my router where I couldn't connect due to an internet issue. I have now reconnected with the internet and now my router is acting weird. This is a dual band and have been using both bands up to this point and now my internet speed has dropped considerably and I can't connect to my 5G band at all. Had a brief connection and showed no mpbs at all. I have reset router to factory settings and still have an issue of only using 1 band. (2.4) but 5g with not connect at all. Any suggestions what I should do. I don't have any firmware updates that I can find so am a little confused
the R7000 has smart connect meaning it combines the 2.4ghz/5ghz bands.
Do you have that enabled? If so, the bands won't show up separately. Might be worth checking.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- spadude60AspirantThanks Furrye38
I did the restart the way you said and put those settings at what you suggested. And now just the 2.4Ghz works. Still can't get the 5Ghz to even show up to connect to. There are no firmware updates and haven't had one in quite a while. So not sure what I should do. Just wondering if second band just is fried or what. We have had this router for approx 7 years. Have never really ever had a problem with it.
Any other suggestions?- plemansGuru - Experienced User
