Pcahill1047's avatar
Pcahill1047
Follower
Jul 23, 2024
R7000
My router was reset and now I have no internet or access. This is hour 14 I’m working on it with no solution. Someone I spent over an hour saying they were NG and taking credit card for $120 was useless. Please help
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Is the Internet LED on the router WHITE or AMBER?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed?
  • michaelkenward's avatar
    michaelkenward
    $120 is not a number I recognise for Netgear's paid support.
    NETGEAR ProSupport for Home | NETGEAR
    Let me guess, you called a number that came up in a Google search. (Google is happy to sell ad space to any crook that pays up.) This is rarely anything to do with Netgear.
    Netgear warns about these scams.
    How do I identify an official NETGEAR website or social media account? - NETGEAR Support
    If you have problems getting something to work, and you are within the 90 days for free support, contact Netgear through the official channels:
    Contact Us | Support | NETGEAR
    First you have to register your device to confirm that it is eligible for free support.
    MyNETGEAR | Product Registration
    Start a case and, with luck, they will contact you.
    After 90 days, there is also the paid-for channel (see above).
    Or you can try to sort out problems here. It costs nothing.
    Many issues are pretty straightforward. A search in this community may throw up something helpful.
