Thilo
Jul 20, 2021Aspirant
R7100LG GSM Modul defekt?
Hi,
i get no more mobile connection with SIM card. SIM card is working in other modems.
I take the router in factory reset but no result.
Because it dont works i make a firmwareupgrade to V1.0.0.64 and while that he say he cant upgrade LTE modul.
And if i start the router
- with SIM(without PIN verification) the page hang on site "detecting mobile settings"
- without SIM the "mobile broadband settings" are grey and i cant setup it
- DarrenMSr. NETGEAR Moderator
Have you tried to revert the firmware to see if those settings start working again?
DarrenM
- ThiloAspirant
Hi DarranM,
Thank you for feedback and info.
I test it with the old firmware downgrade to V1.0.0.52 and same Error message while downgrade:
LTE MODEM UPGRADE FAILED
After reboot same situation: Adjusting for "Mobile Broadnad Settings" are grey and connot adusted.
Hello Thilo
I want to get you to support to work on this issue I have sent you a PM.
DarrenM
