Shiverman45
May 03, 2023Aspirant
R7450 how do I access and change the firewall
My wife recently started working for a company based out of Germany and they sent her a laptop with their specific software installed on it. Our router won't allow the software access and the company's tech guy said it's most likely because of a firewall. I tried disabling settings from the Nighthaawk app but I couldn't find a way to do it so can anyone suggest another way to login to my router settings and remove the firewall?
What modem/gateway do you have?
Have you tried give the laptop a reserved IP address and then putting it in the netgears DMZ?
- Shiverman45Aspirant
My modem and router are all in one. I'm not sure how to do either of those things you mentioned.
The R7450 isn't a modem/router. Its a router-only device.
So its connected to something,what is that?
The manual would be a good place to start with what I recommended.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
