jszar's avatar
jszar
R7500 - No Internet on wifi network
R7500 Nighthawk X4 AC 2350 / Firmware v1.0.0.94 / Mostly Mac devices / Home use
The LAN connection to my iMac USUALLY works, sometimes it does not though. The internet light on the router is blinking white (good internet connection). However no wifi connected devices will connect to the internet. The only fix I've found is restarting the router, which takes ~2 minutes, then it's fine for a 24-36 hour period before the problem comes back. All wifi devices show a solid wifi connection. No firmware updates available. Router has DNS address in routerlogin.net.
  • Hi jszar,
    1. When no internet on wifi, does wired works?
    2. Try setting DNS Address 4.2.2.2 or 8.8.8.8 under internet setup.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi jszar,
    • JamesGL's avatar
      JamesGL
      Hi jszar,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • JamesGL's avatar
        JamesGL
        Hi jszar,
        Is the connection still stable?
  • Wired almost always works. Reset the settings yesterday to your suggested, and it seems to have fixed it. Giving it a solid two days before I say full success though. Thanks!
