TC_E1ite
Feb 21, 2018Aspirant
R7500 Beamforming and MU-MIMO
Hello I noticed that Beamforming and MU-MIMO are not enabled and when I try to enable them the apply button does not work can someone help me fix this my router firmware version is V1.0.0.122 i belie...
- Feb 21, 2018
There are two model variants - R7500 and R7500v2. According to older posts, only later one does support MU-MIMO https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7500-MU-MIMO-Capability/td-p/998027
schumaku
Feb 21, 2018Guru - Experienced User
- TC_E1iteFeb 21, 2018Aspirant
ok thank you, i look into the setting and saw the options for them and i looked up my order on Amazon and the title said that it has Beamforming+ https://www.amazon.co.uk/gp/product/B00N2PPFDM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
so i thought that it had support for it but i assume they must have updated the title after r7500v2 came out
- schumakuFeb 21, 2018Guru - Experienced User
Now I'm a little bit confused. In another thread, a community member has posted the UI screenshot - which does include both Beamforming and MU-MIMO controls - https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7500-v1-does-it-support-mu-mimo/td-p/1506287 unclear if this is a v1 or a v2 variant:
And the R7500 is listed as applicable in the Beamforming FAQs, too.
Check your router UI
- TC_E1iteFeb 22, 2018Aspirant
This is a screenshot of my UI it has the options but i cannot use them because the accept button doesn't work very confusing
