drselz's avatar
drselz
R7500 won't connect to computer ethernet port
Router lights are all white, but ethernet port on computer is yellow, so NO internet. Removing router, and directly cabling modem to computer through ethernet is fine. I have reset router multiple times, tried three different ethernet cables and No connection. I even tried an older Netgear router (N600), which worked for several hours, and then quit working also. Any suggestions?
  • Unfortunately, nothing seemed to correct the problem, so I purchased an R7800. It had trouble connecting also, and I had to reboot into safe mode to install it, and then upgrade the firmware. Since then, all seems to be working!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi drselz,
    1. Try to use all the ports on your router.
    2. Use a different computer.
    3. Check the IP address of the computer when connected to the router.
  • JamesGL's avatar
    JamesGL
    Hi drselz,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    • drselz's avatar
      drselz
