infael's avatar
infael
R7800 - setting up multiple SSIDs
I looked in the R7800 user guide but couldn't seem to find a way to setup multiple SSIDs. How do I do this? Thanks
Mike
  • Specifically how many are you talking about?
    You can have a seperate SSID for the primary 2.4 GHz band and for the primary 5 GHz band.  Then you can have a seperate SSID for the guest 2.4 GHz band and the guest 5 GHz band.  Once you get to four, that is it.
    • infael's avatar
      infael
      I only need 1 separate. Now that I know it can be done, I'll look at the manual more closely. Thanks!
      • infael's avatar
        infael
        I couldn't find info on creating multiple SSIDs in the R7800 manual. How can I create another SSID?
        TIA
        infael
