Funbeads21's avatar
Funbeads21
R7800 Access Denied error on some websites.
I have had problems since I setup my R7800 router. When I tried to connect to some websites, I get an error message. One example is when trying to connect to Southwest.com I get the following error "You don't have permission to access "http://www.southwest.com/" on this server.
Reference #18.8cbc6e68.1695785851.125d3d7b"
I had been using R7500v2 and had no problems.
Nighthawk(R) X4S R7800  Router Firmware Version
V1.0.2.92
  • FURRYe38's avatar
    Are you seeing this problem on one device or across all devices?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Armor, Smart Parental Controls or Circle
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Cleared all browser caches?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Funbeads21's avatar
      Funbeads21
      I get the same error with several websites on all devices. I have had issues with some streaming services not connecting too.
      My R7800 has been updated to the latest firmware   Version V1.0.2.92
      My service provider is Xfinity
      I use my own Arris SB8200 modem
      I have restarted both modem and router several times.
      I have cleared my history and cache.
      I was using a NG R7500v2 and had had no problem going to any websites
      Most websites work fine but there are those that just throw the following error
      Access Denied
      Reference #18.8cbc6e68.1695824681.13ce0007
      Thank you for your interest in my problem. Hopefully you can suggest a solution to solve this problem.
      • FURRYe38's avatar
    V1.0.2.92
    The error is most likely coming from your web browser.  The web address shown above is unencrypted.
    Try https://www.southwest.com
