Naks
Jan 19, 2017Aspirant
R7800 Bridge mode don't work
Hello,
I bought a R7800 (firmware 1.0.2.20), i link my computer and the router with ethernet, and i try to use the bridge mode on the Wifirst's public router. But when i set the bridge mode the routerlogin.com/192.168.1.1 webpage is not accessible, and the bridge don't work. I try to connect the router on the wifi AP of my android phone but i have the same problem.
If someone can help me it could be cool ! :)
Thanks,
None of our home routers supports such feature.
I'm not sure if 3rd-party firmware will help.
- NaksAspirantYes but when my router switch to bridge mode i cant access to the routerlogin.com page and my PC dont detect the router on the ethernet port.
- ElaineMNETGEAR Employee Retired
When the router is set on bridge, it's normal that you will no longer be able to access it through routerlogin.net.
You will need assign a static IP address by selecting "Use Fixed IP Address". Make sure that the IP address that you will assign should be in the same range of the main router.
- NaksAspirant
Ok, because i had access to the page routerlogin.net a little time like 45s in bridge mode, it's why ithink it was possible to go on it.
i try what you propose, but it's don't work. Maybe because i'm not configuring the bridge mode correctly, i'm not a pro :/
I tried with the ip adress shown on my phone when he is connected to the main router for static IP.
