King_Thrawn's avatar
Jan 04, 2018
R7800 does not work with DPC3216 modem
Hello everyone, I tried searching for my problem and did not find any solutions.   I purchased the R7800 and tried to set it up with my DPC3216 (Spectrum) modem today. I correctly power cycled the ...
  • King_Thrawn's avatar
    King_Thrawn
    Jun 12, 2018
    Hi everyone. Sorry that I lost touch with this thread. I managed to solve the issue and before I could post I just became too busy with kids/work and then forgot about it.
    In short, I was able to resolve my issue by cloning my PC mac address on the netgear router. I will do my best to remember the exact steps that I took for anyone who wants to try and replicate it.
    Unplug DPC from the wall for 30 seconds
    Make sure DPC is not connected to anything via ethernet
    Let it fully boot up and get signal with ISP
    Turn on your primary PC
    Hook your PC to the DPC via ethernet and let it discover network, etc. and set up internet
    Open web browser and confirm that you have internet while directly connected to DPC
    Disconnect PC ethernet from DPC modem - leave DPC modem on and running (its now configured for your PC MAC)
    Reboot PC
    Plug in netgear router and perform a factory reset on it (I can't remember if it has a pin hole or other button, but it needs a fresh clean reset)
    After netgear is fully booted up, connect via ethernet to your PC
    Open web browser and go to the main IP that allows you to access the setup menu with default user name and password (I'm sorry but I cannot remember what the defaults were)
    Use the menu options (Advanced options?) to clone your PC MAC address to the netgear router (something like "copy this MAC")
    Be sure to save the settings
    Within the netgear settings you should be able to find an option to reboot the router - go ahead and reboot it
    Wait until netgear router is rebooted, then shut down PC
    Disconnect PC ethernet from netgear
    Here is the part that messed me up quite a bit until I did it by accident - disconnect netgear from power outlet, then power it back up and let it run its startup cycle
    The DPC modem and netgear router should both be on and powered up at this point - connect netgear router to DPC via ethernet
    Let them do the handshake, lots of lights flickering, when its finished you should NOT see the red light on netgear indicating lack of internet access
    Connect PC to netgear routher via ethernet
    Boot up PC, allow network to auto configure
    Open browser and check for internet access
    If it works, then log into the netgear router interface via IP address in the browser and make your account settings and other network (wifi) settings
    I run both my DPC and netgear on a battery backup, so I haven't had them power off for several months and they have kept working great.
    Hope this helps everyone and sorry that I didn't post this sooner when I may have remembered more specific details.
