Knzych's avatar
Knzych
Initiate
Feb 21, 2019
R7800 is giving wrong gateway to wifi device
I bought a R7800 yesterday,
It works well on the lan connection.
However, there is a weird problem on the wifi connection,
the default gateway was set to 192.168.1.1,
But those wifi connected device mostly getting 192.168.30.1 as default gateway and lead to no internet connection to those device.
Even i hard mapped those device ip to 192.168.1.x
It still getting 192.168.30.x ip
Do anyone know how to solve this problem?
i have already updated to the most recent firmware.
Thanks a lot.
  • Knzych's avatar
    Knzych
    Feb 21, 2019
    i just solved
    but still thanks for your help.
    Its due to the secureNAT from softether
    hope anyone who encounter this issue can solve through turning it off
  • do you have a modem-only or a gateway (modem+router) in front of the R7800?
    • Knzych's avatar
      Knzych
      Initiate
      i just solved
      • michaelkenward's avatar
        michaelkenward
        Well done.
        Can you explain what that does? It might help someone who hits a similar issue.
        What is it for?
