Brownk
Oct 27, 2022Aspirant
R7800 Non-Responsive
I am having trouble accessing my R7000 Router.
We experienced a power failure and I turned off our DSL Modem/Router and R7000 Router and disconnected power. When the electricity came back on, I powered up the Routers. Strangely, the R7000 was not providing any Wi-Fi broadcast, from either 2.2 or 5 GHz. The Wi-Fi light was illuminated, but neither of the 2.2 or 5 GHz. were illuminated.
I was able to access the router via Ethernet and was able to access the router’s menu. It showed the Wi-Fi was off on the status page, but according to the both configuration pages, everything was turned on?
Since I could not get the Wi-Fi signals to broadcast, I decided to factory reset and re-config the router. Now I cannot access the router menu. I have tried two computers and multiple browsers. It either states the server cannot be found or the router is busy. The minute I connect an Ethernet cable, the port becomes active (flashing light) and data is being sent and received, immediately. I believe this is why I cannot access the router, because it is transmitting data.
The router was setup behind an AT&T DSL Router/Modem via a WAN port, per AT&T. Only the R7000 was broadcasting Wi-FI.
I have tried everything. Resetting the R7000 to factory, hard resetting, power cycling, verify the ports work and nothing seems to remedy the problem.
Since using a browser will not work, I figure the only hope would be trying to access the router via command line. I have never done so, but fear the firmware has become corrupted.
Should I attempt uploading clean firmware via TFTP? Or, is there a less complex solution that I am not aware of, yet? Since the router seems to be in a constant state of transmission, not sure if it would allow uploading firmware.
I am using Apple hardware running OS 10.13 (High Sierra).
Any assistance would be much appreciated. I would hate to lose the router, as we have had no unresolvable issues, prior. Nothing that a factory reset didn’t resolve. Very strange predicament.
What's seen on the 7000s web page under basic?
Please post a screen capture here however edit out the SSID name and PW before posting.
Are the wifi LEDs on the top of the router ON?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode- BrownkAspirant
Thanks for the prompt reply FURRYe38.
First, I should note that we actually have a R7800, not a R7000.
The Firmware version was 1.0.2.90.
I have a suspicion as to what happened, but it doesn't explain why the 2.2 and 5 GHz signals were not broadcasting (and still do not).
The problem may have been a bad sequence of events that ultimately left the router with partial/corrupted firmware.
When the AT&T Modem/Router came back online, it misconfigured and yet would still access the internet. Unfortunately, when I factory reset the R7800, it defaulted to automatically update the firmware. The router was configured to not do this, as I prefer to check the firmware manually and if need be, download and upload. I was unaware that new firmware (v1.0.2.92) was posted, recently. So the unit started to update the firmware through the misconfigured AT&T Modem/Router. Unfortunately, it was only after I reset the R7800 and sat down with my tablet, that I received a prompt that something was wrong with the AT&T Modem/Router. By then, the damage was done.
Since the firmware was corrupted, I cannot access the R7800 menu via a browser. That an incomplete firmware update has "bricked" the router. Now it is lost in some incomplete process and will not stop.
This leads me to believe the only hope is to try and upload clean firmware via TFTP and a command line. My concern is that since the router is active the minute it is connected to a WAN port, will this approach work?
Regarding DMZ, this was second approach recommended by AT&T. There was no instructions regarding my specific Modem/Router. Found instructions for another model and assume the approach would basically be the same. Our AT&T Modem Router doesn't do "Bridge Mode" in the purest sense. Because I am not the best versed in Networking, I was hesitant to use this approach. Feared it would expose our Network to vulnerabilities beyond my comprehension or visibility. I just started using this approach with the AT&T Modem/Router, recently. Prior, I was using an old Netgear Modem/Router in Bridge Mode, but that model hadn't seen a firmware update in years (DM111PSPv2). I figured it as alright, because it was just acting as a Modem and the R7800 managed the rest.
Even connecting the R7800 to my old old Modem/Router in Bridge Mode doesn't help. Thought being that there should be no conflict that might be part of essentially running two two routers. I cannot access the Internet nor access the R7800 menu. As soon as I connect to a WAN port, the unit starts sending/receiving packets at about 1 per second. The Router will not stop communicating, which prevents accessing the menu. That or that the firmware is too corrupted to function, properly.
Once again, thanks for your assistance in the matter. If I can get the R7800 to work again, I will consider using the ISP provided equipment and the R7800 in DMZ. Not sure if I should just stick with the less complex approach of using the old Netgear Modem/Router in Bridge Mode and the R7800, combination?
This can happen, but rarely. When it does, people usually manage to manually update the firmware.
If the power LED is as expected, solid white, that would be a first move.
When the AT&T Modem/Router came back online, it misconfigured and yet would still access the internet. Unfortunately, when I factory reset the R7800, it defaulted to automatically update the firmware. ?You can prevent that from happening by resetting the R7800 and keeping it of line as it goes through its wizardry. (You should also be able to stop that from happening in the first place.)
You can then manually update the firmware and set it up to prevent automated updates. (I also disable password recovery, which has its own "closed loop" gotcha.)
There are various other tricks, some of which I had to get into when testing the R7800 hardware for another purpose. But the first move should be to try the simplest and safest,
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
 - BrownkAspirant
Michael,
If you are referring to the ISP AT&T Modem/Router, it is a Netgear 7550.
Normally, I ran the old Netgear Modem/Router (DM111PSPv2) in Bridge Mode and had the R7800 handle everything.
We have had serious Internet issue’s over the years. We live in a rural environment and on DSL with a maximum of 6 Mbps.
The last Technician suggested running the R7800 behind the ISP supplied Modem. Normally, we would run either just the ISP supplied device or the prior mentioned Netgear/Netgear setup.
We had been experiencing constant disconnects, so I thought I would try a different configuration. I regret doing so, now.
Why the R7800 refuses to do a complete factory reset is confusing.
Throughout or issue’s, I have had a vehicle on our property line that seems to be running a hotspot. I have watched for this vehicle to move and it has not.
I have tried working with the R7800 connected to just a computer, but if cannot get the thing to factory reset and access it’s menu, it seems I am dead in the water.
I have become suspect that somebody has spoofed the router.
I try to eliminate all interference. Turn off our two tablets, unplug our computer, unplug our smart tv, disconnect and unplug our ISP equipment, but I cannot escape the Wi-Fi from our Neighbor’s. We live in the middle of five acres and the amount of Wi-Fi in the area is unbelievable.
Only thing I know to do is try TFTP via a command line. Hesitant, though.
One of those custom jobs that you can't buy out in the consumer world.
Now pretty ancient. Can it really date back to 2008?
Is this why it is not possible to login to the #browser graphical user interface (GUI)?
- BrownkAspirant
I generally have not been using the ISP equipment with the R7800, since the trouble began, because it will not work. I have been using a computer that is not connected to the Internet.
Don’t get me started on AT&T. That would lead to a very long tirade. Unfortunately, they as usual, are the cheapest internet in our area. They are the only wired, also.
We have been on the same account for sixteen years. Seems DSL went legacy almost a decade ago. Other than AT&T wired, it is all wireless or satellite.
I complained to AT&T that our Neighbors were spoofing our internet. Finally caught a neighbor spoofing via capturing their router using our SSID. Even tough I had a screen print, they would do nothing without something from law enforcement.
Our original ISP Modem died (Siemens Soundstream?). Since we were on legacy status, we bought the Netgear DM111PSPv2 as a replacement. The AT&T unit was expensive and we our on legacy status!
In the years past, still having problems, I contacted AT&T support. I figured our Network was still being spoofed. I asked whether we showed as being connected to the AT&T Server and we were, but it showed no activity even though I was on the internet. That is why I have the AT&T ISP Netgear 7550. The Support Tech was alarmed and sent me a free unit. Something they had refused to do in the past.
From what I can tell, AT&T buys discontinued equipment and installs their own firmware on the unit.
We always used non-wireless via Ethernet. In 2017, my Wife got an iPad, so we needed a Wi-Fi Router. We chose an AirPort Extreme hooked up to the Netgear DM111PSPv2. It was being spoofed (noted above). Started using the ISP supplied Netgear 7550, but it had spotty performance, so we bought the Netgear R7800 and went back to the DM111PSPv2. Started experiencing disconnects, recently, and decided to try the R7800 behind the ISP Netgear 7550. Now, as per this thread, the R7800 is not working.
Years ago, all DSL Modem based units disappeared in unity. Conspiracy?
