sncpa's avatar
sncpa
Guide
Jan 23, 2022
R7800 Updated to 1.0.2.90, now wants to install V1.0.0.423
I checked on my router updates and an update was suggested: V1.0.2.84(~) to V1.0.2.90. Using the firmware assistant, it reported an MD5 Checksum error and failed to install. Per other discussions on the board, I downloaded manually from https://www.netgear.com/support/product/R7800.aspx#Firmware%20Version%201.0.2.90
and installed; that went fine.
After reboot and recheck again with the firmware assistant, it now wants to go from V1.0.0.422 to V1.0.0.423.
None of this should have happened.... what's up? My guess would be that Netgear (and now my router) is compromised!
Debating going back to 1.0.2.84.
If this is some separate download, why is it not in the very latest D/L? And why does it have overlapping version numbers?
      • FURRYe38's avatar
        Thats GUI (Graphical User Interface) langage version update, not FW.
  • FURRYe38's avatar
    Can you all re-check this? I got word from NG that this was fixed on there side.
    • Andydie's avatar
      Andydie
      I also performed the factory reset and always I use a wired PC but always the same issue even now.
      Now I have also found another issue, the router no longer allows changing the language, trying to change the language the GUI always returns to English.
      But is it not possible to download this type of update to do it manually?
      With manual update I was able to update to firmware V1.0.2.90 which otherwise automatically returned the same issue "MD5 verify error"
      Regards
      • FURRYe38's avatar
        Ya, guess not. Hopefully NG will fix it. I've pass this back to NG.
  • I'm in the same boat as you.  It'd ridiculous having to do a factory reset.  Therefore, I'm going to assume that running the current 1.0.2.90 firmware is what's important, and that the v1.0.0.423 GUI update is only relevant for communication between the browser and the the v1.0.2.90 firmware.  I don't know about you, but I only rarely need to access the router GUI, so I can wait.  Obviously Netgear should fix it, but it seems much less important than our fixing the security vulnerabilities, which is the point of the 1.0.2.90 update.
    If someone has a different view, please post!  We're all in this togther.
    • Dirtnap's avatar
      Dirtnap
      I'm having the same issue.  Seems to be a bad firmware update.  Hopefully NG fixes this soon.  Factory resetting this is a bad answer.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi all, thank you for reporting this. This is currently being worked on by the team. We will provide an update as soon as it is available.
        Dexter
        NETGEAR Team
