Kcool's avatar
Kcool
R7800 WiFi
The Genie web browser shows everything is connected, but the Genie app shows that my wireless connection is not enabled.  The app is wrong because my wireless devices are working fine.  What do I need to do to get the app to show the correct status of my network?  Thanks.
  • Hi Kcool,
    It is normal if the Genie app is opened in a wired computer. If you open it in a wireless computer, it will have a status that it is enabled as it detects a wireless card on your computer.
    In a laptop:
    Desktop with no wireless card:
  • I think it's a Genie thing...  I have the same issue if I use Genie, but if I log into the router using a browser it shows all wireless connection information correctly.
    Wish I had an answer for you on how to fix it; but I don't.  Just wanted you to know that you are not the only one experiencing this.
    • VE6CGX's avatar
      VE6CGX
      Master
      As far as I am concerned I never bothered with Genie. In that case I just run ipscan to see
      what is connected with which ip address.
  • Thanks TC, it does make me feel slightly better to know I'm not the only one!  I like the browser just fine, but also like the ability to view connection status when offline.
    I should mention the genie app on android works perfectly. The issue is with windows on a somewhat old desktop.
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi Kcool,
      In a laptop:
      • Kcool's avatar
        Kcool
        That makes perfect sense, thanks for the help James!
