w1's avatar
w1
Initiate
Dec 02, 2020
R7850 Nighthawk AC3000 Router Firmware
I have an R7850 Nighthawk AC3000 Router that randomly drops internet from some of my devices. After reading several other threads regarding this problem, I want to re-install the firmware on it. It is running firmware V1.0.5.52_10.1.67. According to the Nighthawk app and the web interface that version is current, there are no updates for it. I cannot find any firmware downloads for the R7850 Nighthawk AC3000 router. I can find firmware downloads for the R7850 Nighthawk AC3200 router, but this version is not listed there. Does anyone know where I can download this version of the firmware or how I can re-install it?
  • w1 wrote:
    So then the R7850 Nighthawk AC3000 Router is the same as the R7850 Nighthawk AC3200 Router?
    That's one of the hazards of using those "AC" labels.
    AC3000 and AC3200 are not reliable guides to model numbers. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    So stick with the R7850 as the model number and you'll be fine.
    Glad it worked out.
