harryballzanya
Dec 18, 2016Tutor
R7900 5G-2 Band Drops Speed from 200mbps to 2mbps
Hi. Over the past week I've noticed the 5G-2 band on my R7900 will drastically drop speed for no noticeable reason. Last week I change the broadcast channel from 149 to 161, which I thought was the...
- Mar 22, 2017
I found the issue and have got a work around for now. I posted the solution to this new thread for anyone who runs into the issue. I believe it is a firmware issue but it can be mitigated until they fix it. Here is the link to the other thread... https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Do-NOT-use-Dynamic-QoS-on-Nighthawk-R7900/td-p/1251916
I wasted enough time on this. Support can read my notes. Unless they want to pay me for my services.
JamesGL
Dec 26, 2016NETGEAR Employee Retired
Hi harryballzanya,
1. How many devices are affected?
2. Have you tried to reset the router to factory default? If not yet, please press the reset button at the back of the router until the power light turns amber. Manually reconfigure the router after the reset.
JamesGL
Community Team
- harryballzanyaDec 27, 2016Tutor
Thanks for the reply and the help! ALL devices connected to the 5G bands are affected. I will attempted to reset to factory and reconfigure during low usage period and will report back. Thank you!
- JamesGLJan 02, 2017NETGEAR Employee Retired
Hi harryballzanya,
Looking forward for your feedback.
JamesGL
Community Team - JamesGLJan 05, 2017NETGEAR Employee Retired
Hi harryballzanya,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team- harryballzanyaJan 07, 2017Tutor
Sorry for the late reply. My issue was actually escalated to Tier 2 support and because of my router's symptoms I was sent a brand new R7900. I just received it today and will be installing it and sending the old one back. This will help determine if it's simply a hardware issue or a firmware issue. I will keep posting as I have new information.
