spacefish69's avatar
spacefish69
R7960P emailing logs
hello.. I use to get my logs emailed daily. then they stopped. I checked the settings all is same and good info. when I go to the log and click send log. it says email sent with the correct address but it is never recieved. any idea?
    Per chance are you sending to a gmail.com address?
    Did you check to see if the e-mail is landing in your spam/junk mail folder?
    • spacefish69's avatar
      spacefish69
      yes sending to Gmail. have also checked spam etc. have also tried sending to none Gmail.
      I am and was using my internet company email smtp stuff and it was working great.
      • Kitsap's avatar
        Kitsap
        Master
        When using Gmail, are you using the specially generated password for third party applications?
        You are sure you have the outgoing mail server port number correct as well as the mail server authentication option set.
        In your router log, it should show something similar to [email sent to: xxxxxx@gmail.com] Friday, November 18, 2022 05:00:04
