Spawn66
Jan 09, 2016Aspirant
R800 Unable to update firmware
After a succesful installation, update and configuration if my router, I noticed there was a new version of the firmware (1.0.3...).
If I try an automatic update, netgear genie tells me it's up to date, which is not true. So I have tried a manual update with the downloaded file. The problem I have is that each time I try to install it, I have a message that warns me I wull be disconnect from the Internet during the process. So, when the installation begins after a few seconds it stop.
Anything i can do about it?
- Retired_MemberJan 10, 2016
I meant to include do a factory default first .....long day ....
- Retired_Member
What is the complete file name you're trying to load.
- Spawn66AspirantIt's the good file don't worry (*.chk if I remember well).
The problem is the installation process cannot be conpleted because the router disconnect from the web so the installation screen always switch to a new one that indicates the lost of internet connection!
Its kind of frustrating.. - Spawn66AspirantIs it normal to have the warning that the router will disconnect from the internet before trying to upgrade the firmware?
- Retired_Member
....disconnect all other cables including WAN.... Try updating with pc connected via lan port
- Spawn66Aspirant
Ok here's what i did :
Disconnect all cables from the router
Turn off wi-fi
Connect my laptop directly to the router
Connect to the router via www.routerlogin.net
Try to upload and install the .chk file
Doesn't work, same result. I get a page that tell me the webpage is not accessible...
Am I the only one with this issue??
- rckrz6Guide
my r6400 tells me its up to date also when theres a newer version posted on the support page. I don't get it
- JamesGLNETGEAR Employee Retired
Hi rckrz6,
You can update the software manually.
http://kb.netgear.com/app/answers/detail/a_id/23960/~/upgrading-your-router-firmware-manually
