Katman09
May 18, 2024Aspirant
R8000 - Error logging into Mozilla - 404 Fil eor directory not found
I have an AC3200 Tri-Band WiFi router (Nighthawk x6). I used to be able to login to Mozilla to access my dashboard but i receive an error now. I can log in using Edge or Chrome but wondering why i can't use Mozilla. Anyone have any suggestions? I was at first concerned someone got into my network. Thank you!
Frank
Probably because they changed something in Mozilla.
Your router doesn't look around and say "Here comes Mozilla. Batten down the hatches."
As browsers get more and more security conscious they put on more layers of protection. If anything, I find that Firefox causes less trouble on that front.
Have you looked at the security warnings?
- MarkK11Aspirant
Katman09 wrote: Manage Publix passportI have an AC3200 Tri-Band WiFi router (Nighthawk x6). I used to be able to login to Mozilla to access my dashboard but i receive an error now. I can log in using Edge or Chrome but wondering why i can't use Mozilla. Anyone have any suggestions? I was at first concerned someone got into my network. Thank you!
Frank
The issue with Mozilla might be due to a browser-specific problem such as cache or extensions. Try clearing your Mozilla browser cache and disabling any add-ons. If the problem persists, consider resetting Mozilla to its default settings. Rest assured, it’s unlikely that this issue indicates a security breach in your network.
