MrZen
Mar 27, 2017Aspirant
R8000 Firmware Update R8000-V1.0.3.36_1.1.25 breaks genie app, local and remote management
Upgrade to V1.0.3.36_1.1.25 has left me not being able to remotely or locally manage router using the genie app. I have also noticed the router being very sluggish with connectivity since the upgrade last night. Resetting does not resolve the issues.
- Do I need the previous fw to roll that back? If so where can I get it? Thanks!
- storm1985Prodigy
if you revert it back to the old firmware v1.0.3.4 will it work properly?
- MrZenAspirantDo I need the previous fw to roll that back? If so where can I get it? Thanks!
- MrZenAspirant
I rolled it back to V1.0.3.32_1.1.21 bits and everything back to normal, this current relase should be pulled to fix the issues then released again.
- MrZenAspiranthttp://downloadcenter.netgear.com just search R8000 and select the correct bits.
- ElaineMNETGEAR Employee Retired
Did it work after updating the firmware once again?
