horacemiles
Apr 19, 2022Tutor
R8000 HARDWIRE CONNECTIONS HAVE INTERNET BUT WIFI CONNECTIONS DO NOT
Hardware version R8000
FIRMWARE VERSION : V1.0.4.84_10.1.84
After upgrading to this firmware version, I restored the old configuration because I lost all the advance configurations. All hardwared devices are able to connect to the network, but all of my wifi devices are able to connect to the 2.4 and 5G networks but they are unable to connect to the internet.
To repeat hardware devices can access the internet. All wireless devices can connect to wifi, but are unable to connect to the internet.
Hardwired and wireless devices are recieving IP information from the router and are on the same network.
Guest Network is enabled and will not disable. i.e when I uncheck Enable Guest Network and then apply, the Guest Network is reenabled.
So second issue is unable to to disabe the guest network.
Glad the reset worked. If see DNS errors or issues, enable IPv6 and set to auto. Should help resolve that.
Enjoy. 📡
Additional I need to add all hardware wired devices are able to access the internet. Only wifi devices can not access the internet!
1. what modem/gateway is it connected to?
2. try factory resetting and don't install using a backup configuration. If something is corrupt in the backup, that could be causing the issue.
It is connected to a cable modem ISP provided. All hardwired connections can access the internet. Only Wifi connections are unable to access the internet. This router is used for a buisness with many configurations. Are you saying that everytime this router updates, I will have reenter all of this configuration information?
horacemiles wrote:
It is connected to a cable modem ISP provided----doesn't tell me much. what model modem is it? . All hardwired connections can access the internet. Only Wifi connections are unable to access the internet.---I got that from your prior post. This router is used for a buisness with many configurations. Are you saying that everytime this router updates, I will have reenter all of this configuration information?----I didn't say that. But when you're having issues after an update, a factory reset and new install is one of the first things I'd recommend. You usually don't need to do a thing after a firmware upgrade. But if something was corrupt in a setting or something changed enough, thats where we start.
